  1. Hey I Downloaded Showtime Teg-Vcd release and Jacked Up FTF release, i opened the bin file in cdrwin burned it but cant watch on my compwindows media player shows a error so is WinDVD
    but the mpg is watchable
    i tried to extract the file with vcdgear and then burn it with nero but it gives a error stream encoding which is invalid for [Super] VideoCD
    and i also cant open the mpg in TMPGEnC it says cannot open or unsupported and when i try to open it in dvd2avi it just doesnt load
    Anyone Can Help?
    Thanx In Advance
  2. When you use VCDGear it extracts the SVCD as a VCD so you have to demux it then remux it to a SVCD. And WMP doesn't play SVCDs nor do older versions of WinDVD I think.
  3. uh demux and remux? how do i do that? in tmpgenc at mpeg tools it says Illegal Mpg format
  4. i mean illegal mpeg system stream
  5. It says that when you extract the mpeg then try to mux it in TMPGEnc?
  6. it shows the error when i choose the mpg has the input file
  7. i also tried to extract the DAT file with VCDGear,...but when i try to convert from DAT 2 MPG it says invalid MPG packet size
